REST API reference
Delete a quota policy rule
DELETE /storage/quota/rules/{uuid}
Introduced In: 9.7
Deletes a quota policy rule.
  • quota policy rule delete
uuid
string
path
True
Rule UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
5308545
The specified quota rule UUID is invalid.
5308561
Failed to obtain volume quota state or invalid quota state obtained for volume.
5308569
Quota policy rule delete operation succeeded, but quota resize failed due to internal error.
5308572
Quota policy rule delete operation succeeded, however the rule is still being enforced. To stop enforcing the rule, disable quotas and enable them again for this volume.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
