Delete a quota policy rule
Removes a quota policy rule, typically when you need to manage or update your storage resource quotas.
HTTP method and endpoint
DELETE /storage/quota/rules/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes a quota policy rule.
Related ONTAP commands
quota policy rule delete
uuid |
string |
path |
True |
Rule UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5308545 |
The specified quota rule UUID is invalid. |
5308561 |
Failed to obtain volume quota state or invalid quota state obtained for volume. |
5308569 |
Quota policy rule delete operation succeeded, but quota resize failed due to internal error. |
5308572 |
Quota policy rule delete operation succeeded, however the rule is still being enforced. To stop enforcing the rule, disable quotas and enable them again for this volume. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
