REST API reference
Deletes a quota policy rule
learn more
  • [doc /storage/quota/rules](#docs-storage-storage_quota_rules)
DELETE /storage/quota/rules/{rule.uuid}
Deletes a quota policy rule.
  • quota policy rule delete
rule.uuid
string
path
True
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
5308545
The specified quota rule UUID is invalid.
5308561
Failed to obtain volume quota state or invalid quota state obtained for volume.
5308547
Failed to delete the quota policy rule.
5308567
Quota policy rule delete operation succeeded, but quota resize failed due to internal error.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
