Storage quota rules endpoint overview
Overview
Quotas are defined in quota rules specific to FlexVols or FlexGroup volumes. Each quota rule has a type. The type can be "user", "group", or "tree".
– User rules must have the user property and qtree property.
– Group rules must have the group property and qtree property.
– Tree rules must have the qtree property and not have the user or group property.
Quota policy rule APIs
The following APIs can be used to perform create, retrieve, modify, and delete operations related to quota policy rules.
– POST /api/storage/quota/rules
– GET /api/storage/quota/rules
– GET /api/storage/quota/rules/{rule-uuid}
– PATCH /api/storage/quota/rules/{rule-uuid}
– DELETE /api/storage/quota/rules/{rule-uuid}
Retrieving all quota policy rules
This API is used to retrieve all quota policy rules.
The following example shows how to retrieve quota policy rules for FlexVols and FlexGroup volumes.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/quota/rules' -H 'accept: application/hal+json'
# The response:
"records": [
"svm": {
"uuid": "038545f8-9ff8-11e8-bce6-005056a73bed",
"name": "svm1",
"href": "/api/svm/svms/038545f8-9ff8-11e8-bce6-005056a73bed"
"volume": {
"uuid": "ab3df793-0f02-43c6-9514-4f142fc8cc92",
"name": "vol1",
"href": "/api/storage/volumes/ab3df793-0f02-43c6-9514-4f142fc8cc92"
"uuid": "66319cbe-b837-11e8-9c5a-005056a7e88c",
"href": "/api/storage/quota/rules/66319cbe-b837-11e8-9c5a-005056a7e88c"
"svm": {
"name": "svm1",
"volume": {
"name": "vol1",
"uuid": "dbd5b443-b7a4-11e8-bc58-005056a7e88c",
"href": "/api/storage/quota/rules/dbd5b443-b7a4-11e8-bc58-005056a7e88c"
"num_records": 2,
"href": "/api/storage/quota/rules"
Retrieving a specific quota policy rule
This API is used to retrieve a quota policy rule for a specific qtree.
The following example shows how to retrieve a quota policy user rule for a specific qtree.
# The API:
GET /api/storage/quota/rules/{rule.uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/quota/rules/264a9e0b-2e03-11e9-a610-005056a7b72d' -H 'accept: application/hal+json'
# Response for a user rule at a qtree level:
"svm": {
"uuid": "fd5db15a-15b9-11e9-a6ad-005056a760e0",
"name": "svm1",
"href": "/api/svm/svms/fd5db15a-15b9-11e9-a6ad-005056a760e0"
"volume": {
"uuid": "c1b64eea-ca8b-45ec-9397-ab489830d268",
"name": "vol1",
"href": "/api/storage/volumes/c1b64eea-ca8b-45ec-9397-ab489830d268"
"uuid": "264a9e0b-2e03-11e9-a610-005056a7b72d",
"type": "user",
"users": [ {"name" : "fred"} ],
"qtree": {
"name": "qt1",
"id": 1,
"href": "/api/storage/qtrees/c1b64eea-ca8b-45ec-9397-ab489830d268/1"
"user_mapping": on,
"space": {
"hard_limit": 1222800,
"soft_limit": 51200
"files": {
"hard_limit": 100,
"soft_limit": 80
"href": "/api/storage/quota/rules/264a9e0b-2e03-11e9-a610-005056a7b72d"
Retrieving a quota policy multi-user rule at the volume level
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/quota/rules/0ab84fba-19aa-11e9-a04d-005056a72f42' -H 'accept: application/hal+json'
# Response for a multi-user rule at volume level:
"svm": {
"name": "svm1",
"volume": {
"name": "vol1",
"uuid": "0ab84fba-19aa-11e9-a04d-005056a72f42",
"type": "user",
"users": [
"name": "sam",
"name": "smith",
"id": "300010",
"space": {
"soft_limit": 51200
"files": {
"hard_limit": 100,
"soft_limit": 80
"href": "/api/storage/quota/rules/0ab84fba-19aa-11e9-a04d-005056a72f42"
Retrieving a quota policy default tree rule
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/quota/rules/4a276b8c-1753-11e9-8101-005056a760e0' -H 'accept: application/hal+json'
# Response for a default tree rule:
"svm": {
"name": "svm1",
"volume": {
"name": "vol1",
"uuid": "4a276b8c-1753-11e9-8101-005056a760e0",
"type": "tree",
"qtree": {
"name": ""
"space": {
"hard_limit": 1034000,
"soft_limit": 51200
"files": {
"hard_limit": 20,
"soft_limit": 10
"href": "/api/storage/quota/rules/4a276b8c-1753-11e9-8101-005056a760e0"
Retrieving a quota policy tree rule for a specific qtree
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/quota/rules/49b1134f-19ab-11e9-a04d-005056a72f42' -H 'accept: application/hal+json'
# Response for a tree rule for a specific qtree:
"svm": {
"name": "svm1",
"volume": {
"name": "vol1",
"uuid": "49b1134f-19ab-11e9-a04d-005056a72f42",
"type": "tree",
"qtree": {
"name": "qt1",
"id": 1,
"space": {
"hard_limit": 1048576,
"soft_limit": 838861
"files": {
"hard_limit": 100,
"soft_limit": 40
"href": "/api/storage/quota/rules/49b1134f-19ab-11e9-a04d-005056a72f42"
Retrieving a quota policy group rule for a specific qtree
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/quota/rules/b9236852-19ab-11e9-a04d-005056a72f42' -H 'accept: application/hal+json'
# Response for a group rule:
"svm": {
"name": "svm1",
"volume": {
"name": "vol1",
"uuid": "b9236852-19ab-11e9-a04d-005056a72f42",
"type": "group",
"group": {"name" : "group1"},
"qtree": {
"name": "qt1",
"id": 1,
"space": {
"hard_limit": 2097152,
"soft_limit": 1572864
"files": {
"hard_limit": 250,
"soft_limit": 200
"href": "/api/storage/quota/rules/b9236852-19ab-11e9-a04d-005056a72f42"
Creating a quota policy rule
This API is used to create a new quote policy rule.
The following example shows how to create a quota policy user rule using POST.
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/storage/quota/rules?return_records=true' -H 'accept: application/hal+json' -d @test_quota_post.txt
test_quota_post.txt(body):
"svm": {
"name": "svm1"
"volume": {
"name": "vol1"
"type": "user",
"users": [ {"name" : "jsmith"} ],
"qtree": {
"name":"qt1"
"user_mapping": "on",
"space": {
"hard_limit": 8192,
"soft_limit": 1024
"files": {
"hard_limit": 20,
"soft_limit": 10
# The response
"num_records": 1,
"records": [
"svm": {
"name": "svm1"
"volume": {
"name": "fv"
"uuid": "3220eea6-5049-11e9-bfb7-005056a7f717",
"type": "user",
"users": [
"name" : "jsmith"
"qtree": {
"name": "qt1"
"space": {
"hard_limit": 8192,
"soft_limit": 1024
"files": {
"hard_limit": 20,
"soft_limit": 10
"href": "/api/storage/quota/rules/3220eea6-5049-11e9-bfb7-005056a7f717"
"job": {
"uuid": "32223924-5049-11e9-bfb7-005056a7f717",
"href": "/api/cluster/jobs/32223924-5049-11e9-bfb7-005056a7f717"
Creating a quota policy group rule using POST.
# The API:
# The call:
"svm": {
"name": "svm1"
"volume": {
"name": "vol1"
"type": "group",
"group": {
"name" : "test_group1"
"qtree": {
"name":"qt1"
"space": {
"hard_limit": 8192,
"soft_limit": 1024
"files": {
"hard_limit": 20,
"soft_limit": 10
# The response
"num_records": 1,
"records": [
"svm": {
"name": "svm1"
"volume": {
"name": "fv"
"uuid": "3b130f7d-504a-11e9-bfb7-005056a7f717",
"type": "group",
"group": {
"qtree": {
"name": "qt1"
"space": {
"hard_limit": 8192,
"soft_limit": 1024
"files": {
"hard_limit": 20,
"soft_limit": 10
"href": "/api/storage/quota/rules/3b130f7d-504a-11e9-bfb7-005056a7f717"
"job": {
Creating a quota policy tree rule using POST
# The API:
# The call:
"svm": {
"name": "svm1"
"volume": {
"name": "vol1"
"type": "tree",
"qtree": {
"name":"qt1"
"space": {
"hard_limit": 8192,
"soft_limit": 1024
"files": {
"hard_limit": 20,
"soft_limit": 10
# The response
"num_records": 1,
"records": [
"svm": {
"name": "svm1"
"volume": {
"name": "fv"
"uuid": "e5eb03be-504a-11e9-bfb7-005056a7f717",
"type": "tree",
"qtree": {
"name": "qt1"
"space": {
"hard_limit": 8192,
"soft_limit": 1024
"files": {
"hard_limit": 20,
"soft_limit": 10
"href": "/api/storage/quota/rules/e5eb03be-504a-11e9-bfb7-005056a7f717"
"job": {
Updating the quota policy rule
This API is used to update a quota policy rule.
The following example shows how to update a quota policy rule.
# The API:
PATCH /storage/quota/rules/{rule.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/quota/rules/364d38eb-8e87-11e8-a806-005056a7e73a" -H 'accept: application/hal+json' -d "@test_quota_patch.txt"
test_quota_patch.txt(body):
"space": {
"hard_limit": 16554,
"soft_limit": 8192
"files": {
"hard_limit": 40,
"soft_limit": 20
Deleting the quota policy rule
This API is used to delete a quota policy rule.
The following example shows how to delete a quota policy rule.
# The API:
DELETE /storage/quota/rules/{rule.uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/quota/rules/364d38eb-8e87-11e8-a806-005056a7e73a" -H 'accept: application/hal+json'
