Delete a volume efficiency policy
Deletes a volume efficiency policy to remove its configuration from the system when it is no longer needed.
HTTP method and endpoint
DELETE /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
volume efficiency policy delete
Learn more
uuid |
string |
path |
True |
Volume efficiency policy UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Code
| Error Code | Description |
6881346 |
The policy was not deleted because the policy is in use by at least one volume. |
6881347 |
This operation cannot be performed because the specified policy is owned by the cluster admin. |
6881431 |
The specified policy is a predefined policy and cannot be deleted. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
