REST API reference
Delete a volume efficiency policy
Deletes a volume efficiency policy to remove it from the system when it is no longer needed.
HTTP method and endpoint
DELETE /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
  • volume efficiency policy delete
uuid
string
path
True
Volume efficiency policy UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
6881346
The policy was not deleted because the policy is in use by at least one volume.
6881347
This operation cannot be performed because the specified policy is owned by the cluster admin.
6881431
The specified policy is a predefined policy and cannot be deleted.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
