Retrieve an application component
Retrieves an application component to access how an application interfaces with provisioned storage. This access provides the necessary details to connect to the storage elements used by the application.
HTTP method and endpoint
GET /application/applications/{application.uuid}/components/{uuid}
Introduced in
ONTAP 9.6
Overview
The application component object exposes how to access an application. Most application interfaces abstract away the underlying ONTAP storage elements, but this interface exposes what is necessary to connect to and uses the storage that is provisioned for an application. See the application component model for a detailed description of each property.
Access
Each application component can be accessed via NFS, CIFS, or SAN. NFS and CIFS access can be enabled simultaneously. Each access section includes a backing_storage property. This property is used to correlate the storage elements with the access elements of the application. The backing_storage portion of the access section provides the type and uuid of the backing storage. There is another backing_storage property at the same level as the access properties which contains lists of backing storage elements corresponding to the types listed in the access section.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
path |
True |
Application component UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
application |
backing_storage |
cifs_access |
array[application_cifs_properties] |
file_system |
string |
Defines the type of file system that will be installed on this application component. |
host_management_url |
string |
Host management URL |
host_name |
string |
L2 Host FQDN |
name |
string |
Application component name |
nfs_access |
array[application_nfs_properties] |
nvme_access |
array[application_nvme_access] |
protection_groups |
san_access |
array[application_san_access] |
storage_service |
svm |
uuid |
string |
The application component UUID. Valid in URL. |
"href": "/api/resourcelink"
"application": {
"name": "string",
"uuid": "string"
"backing_storage": {
"luns": [
"creation_timestamp": "string",
"path": "string",
"size": 0,
"uuid": "string"
"namespaces": [
"name": "string",
"size": 0,
"uuid": "string"
"volumes": [
"name": "string",
"size": 0,
"uuid": "string"
"cifs_access": [
"type": "string",
"uuid": "string"
"ips": [
"string"
"path": "string",
"permissions": [
"access": "string",
"user_or_group": "string"
"server": {
"name": "string"
"share": {
"name": "string"
"file_system": "string",
"host_management_url": "string",
"host_name": "string",
"name": "string",
"nfs_access": [
"type": "string",
"uuid": "string"
"export_policy": {
"name": "string"
"ips": [
"string"
"path": "string",
"permissions": [
"access": "string",
"host": "string"
"nvme_access": [
"type": "string",
"uuid": "string"
"subsystem_map": {
"anagrpid": "string",
"nsid": "string",
"subsystem": {
"hosts": [
"nqn": "string"
"name": "string",
"uuid": "string"
"protection_groups": [
"name": "string",
"rpo": {
"local": {
"description": "string",
"name": "string"
"remote": {
"name": "string"
"uuid": "string"
"san_access": [
"type": "string",
"uuid": "string"
"lun_mappings": [
"fcp": [
"interface": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"igroup": {
"initiators": [
"string"
"name": "string",
"uuid": "string"
"iscsi": [
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"port": 3260
"lun_id": 0
"serial_number": "string"
"storage_service": {
"name": "string",
"uuid": "string"
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
application
_links |
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
application_lun_object
LUN object
creation_timestamp |
string |
LUN creation time |
path |
string |
LUN path |
size |
integer |
LUN size |
uuid |
string |
LUN UUID |
application_namespace_object
Namespace object
_links |
string |
Namespace creation time |
name |
string |
Namespace name |
size |
integer |
Namespace size |
uuid |
string |
Namespace UUID |
application_volume_object
Volume object
string |
Creation time |
name |
string |
Name |
size |
integer |
Size |
uuid |
string |
UUID |
application_backing_storage
luns |
array[application_lun_object] |
namespaces |
array[application_namespace_object] |
volumes |
array[application_volume_object] |
backing_storage
type |
string |
Backing storage type |
uuid |
string |
Backing storage UUID |
permissions
access |
string |
Access granted to the user or group |
user_or_group |
string |
User or group |
server
name |
string |
Server name |
name |
string |
Share name |
backing_storage |
ips |
array[string] |
path |
string |
Junction path |
permissions |
array[permissions] |
server |
share |
export_policy
name |
string |
Export policy name |
permissions
access |
string |
Access granted to the host |
host |
string |
Host granted access |
backing_storage |
export_policy |
ips |
array[string] |
path |
string |
Junction path |
permissions |
self
self |
_links
self |
hosts
_links |
nqn |
string |
Host |
subsystem
_links |
hosts |
array[hosts] |
name |
string |
Subsystem name |
uuid |
string |
Subsystem UUID |
subsystem_map
Subsystem map object
anagrpid |
string |
Subsystem ANA group ID |
nsid |
string |
Subsystem namespace ID |
subsystem |
Application NVME access
backing_storage |
is_clone |
boolean |
Clone |
subsystem_map |
Subsystem map object |
local
description |
string |
A detailed description of the local RPO. This includes details on the Snapshot copy schedule. |
name |
string |
The local RPO of the component. This indicates how often component Snapshot copies are automatically created. |
remote
description |
string |
A detailed description of the remote RPO. |
name |
string |
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster. |
rpo
local |
remote |
application_protection_groups
name |
string |
Protection group name |
rpo |
uuid |
string |
Protection group UUID |
fc_interface_reference
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
application_san_access_fcp_endpoint
A Fibre Channel Protocol (FCP) access endpoint for the LUN.
interface |
An FC interface. |
igroup
initiators |
array[string] |
name |
string |
Igroup name |
uuid |
string |
Igroup UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
application_san_access_iscsi_endpoint
An iSCSI access endpoint for the LUN.
_links |
interface |
A network interface. Either UUID or name may be supplied on input. |
port |
integer |
The TCP port number of the iSCSI access endpoint. |
application_lun_mapping_object
fcp |
All possible Fibre Channel Protocol (FCP) access endpoints for the LUN. |
igroup |
iscsi |
All possible iSCSI access endpoints for the LUN. |
lun_id |
integer |
LUN ID |
backing_storage |
is_clone |
boolean |
Clone |
lun_mappings |
serial_number |
string |
LUN serial number |
storage_service
name |
string |
Storage service name |
uuid |
string |
Storage service UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
