REST API reference
Retrieve an application component
Retrieves an application component to access how an application interfaces with provisioned storage. This access provides the necessary details to connect to the storage elements used by the application.
HTTP method and endpoint
GET /application/applications/{application.uuid}/components/{uuid}
Introduced in
ONTAP 9.6
Overview
The application component object exposes how to access an application. Most application interfaces abstract away the underlying ONTAP storage elements, but this interface exposes what is necessary to connect to and uses the storage that is provisioned for an application. See the application component model for a detailed description of each property.
Access
Each application component can be accessed via NFS, CIFS, or SAN. NFS and CIFS access can be enabled simultaneously. Each access section includes a backing_storage property. This property is used to correlate the storage elements with the access elements of the application. The backing_storage portion of the access section provides the type and uuid of the backing storage. There is another backing_storage property at the same level as the access properties which contains lists of backing storage elements corresponding to the types listed in the access section.
Learn more
application.uuid
string
path
True
Application UUID
uuid
string
path
True
Application component UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
application
application
backing_storage
application_backing_storage
cifs_access
array[application_cifs_properties]
file_system
string
Defines the type of file system that will be installed on this application component.
host_management_url
string
Host management URL
host_name
string
L2 Host FQDN
name
string
Application component name
nfs_access
array[application_nfs_properties]
nvme_access
array[application_nvme_access]
protection_groups
array[application_protection_groups]
san_access
array[application_san_access]
storage_service
storage_service
svm
svm
uuid
string
The application component UUID. Valid in URL.
      "href": "/api/resourcelink"
  "application": {
    "name": "string",
    "uuid": "string"
  "backing_storage": {
    "luns": [
        "creation_timestamp": "string",
        "path": "string",
        "size": 0,
        "uuid": "string"
    "namespaces": [
        "name": "string",
        "size": 0,
        "uuid": "string"
    "volumes": [
        "name": "string",
        "size": 0,
        "uuid": "string"
  "cifs_access": [
        "type": "string",
        "uuid": "string"
      "ips": [
        "string"
      "path": "string",
      "permissions": [
          "access": "string",
          "user_or_group": "string"
      "server": {
        "name": "string"
      "share": {
        "name": "string"
  "file_system": "string",
  "host_management_url": "string",
  "host_name": "string",
  "name": "string",
  "nfs_access": [
        "type": "string",
        "uuid": "string"
      "export_policy": {
        "name": "string"
      "ips": [
        "string"
      "path": "string",
      "permissions": [
          "access": "string",
          "host": "string"
  "nvme_access": [
        "type": "string",
        "uuid": "string"
      "subsystem_map": {
        "anagrpid": "string",
        "nsid": "string",
        "subsystem": {
          "hosts": [
              "nqn": "string"
          "name": "string",
          "uuid": "string"
  "protection_groups": [
      "name": "string",
      "rpo": {
        "local": {
          "description": "string",
          "name": "string"
        "remote": {
          "name": "string"
      "uuid": "string"
  "san_access": [
        "type": "string",
        "uuid": "string"
      "lun_mappings": [
          "fcp": [
              "interface": {
                "name": "fc_lif1",
                "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
                "wwpn": "20:00:00:50:56:b4:13:a8"
          "igroup": {
            "initiators": [
              "string"
            "name": "string",
            "uuid": "string"
          "iscsi": [
              "interface": {
                "ip": {
                  "address": "10.10.10.7"
                "name": "lif1",
              "port": "3260"
          "lun_id": 0
      "serial_number": "string"
  "storage_service": {
    "name": "string",
    "uuid": "string"
  "svm": {
    "name": "string",
    "uuid": "string"
  "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
application
_links
_links
name
string
Application name
uuid
string
The application UUID. Valid in URL.
application_lun_object
LUN object
creation_timestamp
string
LUN creation time
path
string
LUN path
size
integer
LUN size
uuid
string
LUN UUID
application_namespace_object
Namespace object
_links
_links
creation_timestamp
string
Namespace creation time
name
string
Namespace name
size
integer
Namespace size
uuid
string
Namespace UUID
application_volume_object
Volume object
creation_timestamp
string
Creation time
name
string
Name
size
integer
Size
uuid
string
UUID
luns
array[application_lun_object]
namespaces
array[application_namespace_object]
volumes
array[application_volume_object]
backing_storage
type
string
Backing storage type
uuid
string
Backing storage UUID
permissions
access
string
Access granted to the user or group
user_or_group
string
User or group
server
name
string
Server name
share
name
string
Share name
backing_storage
backing_storage
ips
array[string]
path
string
Junction path
permissions
array[permissions]
server
server
share
share
export_policy
name
string
Export policy name
permissions
access
string
Access granted to the host
host
string
Host granted access
backing_storage
backing_storage
export_policy
export_policy
ips
array[string]
path
string
Junction path
permissions
array[permissions]
self
self
self
self
hosts
_links
_links
nqn
string
Host
subsystem
_links
_links
hosts
array[hosts]
name
string
Subsystem name
uuid
string
Subsystem UUID
subsystem_map
Subsystem map object
anagrpid
string
Subsystem ANA group ID
nsid
string
Subsystem namespace ID
subsystem
subsystem
Application NVME access
backing_storage
backing_storage
is_clone
boolean
Clone
subsystem_map
subsystem_map
local
description
string
A detailed description of the local RPO. This includes details on the Snapshot copy schedule.
name
string
The local RPO of the component. This indicates how often component Snapshot copies are automatically created.
remote
description
string
A detailed description of the remote RPO.
name
string
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster.
rpo
local
local
remote
remote
name
string
Protection group name
rpo
rpo
uuid
string
Protection group UUID
fc_interface_reference
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
application_san_access_fcp_endpoint
A Fibre Channel Protocol (FCP) access endpoint for the LUN.
interface
An FC interface.
igroup
initiators
array[string]
name
string
Igroup name
uuid
string
Igroup UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
_links
_links
ip
ip
IP information
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
application_san_access_iscsi_endpoint
An iSCSI access endpoint for the LUN.
_links
_links
interface
interface
port
integer
The TCP port number of the iSCSI access endpoint.
application_lun_mapping_object
fcp
array[application_san_access_fcp_endpoint]
All possible Fibre Channel Protocol (FCP) access endpoints for the LUN.
igroup
igroup
iscsi
array[application_san_access_iscsi_endpoint]
All possible iSCSI access endpoints for the LUN.
lun_id
integer
LUN ID
backing_storage
backing_storage
is_clone
boolean
Clone
lun_mappings
array[application_lun_mapping_object]
serial_number
string
LUN serial number
storage_service
name
string
Storage service name
uuid
string
Storage service UUID
svm
name
string
SVM name
uuid
string
SVM UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
