REST API reference
Retrieve application component Snapshot copies
Retrieves Snapshot copies of an application component to access more granular details of the application's state. This is particularly useful for Maxdata template applications where detailed snapshots are necessary.
HTTP method and endpoint
GET /application/applications/{application.uuid}/components/{component.uuid}/snapshots
Introduced in
ONTAP 9.6
Usage notes
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
application.uuid
string
path
True
Application UUID
component.uuid
string
path
True
Application Component UUID
component.name
string
query
False
Filter by Application Component Name
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
consistency_type
string
query
False
Filter by consistency_type
comment
string
query
False
Filter by comment
create_time
string
query
False
Filter by create_time
is_partial
string
query
False
Filter by is_partial
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[application_component_snapshot]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "application": {
        "name": "string",
        "uuid": "string"
      "comment": "string",
      "component": {
        "name": "string",
        "uuid": "string"
      "consistency_type": "string",
      "create_time": "string",
      "name": "string",
      "svm": {
        "name": "string",
        "uuid": "string"
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
application
_links
_links
name
string
Application Name
uuid
string
Application UUID. Valid in URL
component
_links
_links
name
string
Component Name
uuid
string
Component UUID
svm
name
string
SVM Name
uuid
string
SVM UUID
_links
_links
application
application
comment
string
Comment. Valid in POST
component
component
consistency_type
string
Consistency Type. This is for categorization only. A Snapshot copy should not be set to application consistent unless the host application is quiesced for the Snapshot copy. Valid in POST
create_time
string
Creation Time
is_partial
boolean
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy.
name
string
Snapshot copy name. Valid in POST
svm
svm
uuid
string
Snapshot copy UUID. Valid in URL
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
