REST API reference
Retrieve a schedule
Retrieves the details of a schedule, which helps you manage and automate repetitive tasks efficiently.
HTTP method and endpoint
GET /cluster/schedules/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a schedule.
uuid
string
path
True
Schedule UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
cluster
cluster
The cluster that owns the schedule. Defaults to the local cluster.
cron
cron
Details for schedules of type cron.
interval
string
An ISO-8601 duration formatted string.
name
string
Schedule name. Required in the URL or POST body.
scope
string
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
svm
svm
type
string
Schedule type
uuid
string
Job schedule UUID
      "href": "/api/resourcelink"
  "cluster": {
    "name": "cluster1",
  "cron": {
    "days": [
      "integer"
    "hours": [
      "integer"
    "minutes": [
      "integer"
    "months": [
      "integer"
    "weekdays": [
      "integer"
  "interval": "P1DT2H3M4S",
  "name": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cluster
name
string
Cluster name
uuid
string
Cluster UUID
cron
days
array[integer]
The days of the month the schedule runs. Leave empty for all.
hours
array[integer]
The hours of the day the schedule runs. Leave empty for all.
minutes
array[integer]
The minutes the schedule runs. Required on POST for a cron schedule.
months
array[integer]
The months of the year the schedule runs. Leave empty for all.
weekdays
array[integer]
The weekdays the schedule runs. Leave empty for all.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
