Retrieve a schedule
GET /cluster/schedules/{uuid}
Introduced In: 9.6
Retrieves a schedule.
uuid  |
string  |
path  |
True  |
Schedule UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
cluster  |
The cluster that owns the schedule. Defaults to the local cluster.  |
cron  |
Details for schedules of type cron.  |
interval  |
string  |
An ISO-8601 duration formatted string.  |
name  |
string  |
Schedule name. Required in the URL or POST body.  |
scope  |
string  |
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
type  |
string  |
Schedule type  |
uuid  |
string  |
Job schedule UUID  |
      "href": "/api/resourcelink"
  "cluster": {
    "name": "cluster1",
  "cron": {
    "days": [
      "integer"
    "hours": [
      "integer"
    "minutes": [
      "integer"
    "months": [
      "integer"
    "weekdays": [
      "integer"
  "interval": "P1DT2H3M4S",
  "name": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
cluster
name  |
string  |
Cluster name  |
uuid  |
string  |
Cluster UUID  |
cron
days  |
array[integer]  |
The days of the month the schedule runs. Leave empty for all.  |
hours  |
array[integer]  |
The hours of the day the schedule runs. Leave empty for all.  |
minutes  |
array[integer]  |
The minutes the schedule runs. Required on POST for a cron schedule.  |
months  |
array[integer]  |
The months of the year the schedule runs. Leave empty for all.  |
weekdays  |
array[integer]  |
The weekdays the schedule runs. Leave empty for all.  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
