Retrieve a schedule
GET /cluster/schedules/{uuid}
Retrieves a schedule.
Learn more
uuid |
string |
path |
True |
Schedule UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cluster |
The cluster that owns the schedule. Defaults to the local cluster. |
cron |
Details for schedules of type cron. |
interval |
string |
An ISO-8601 duration formatted string. |
name |
string |
Schedule name. Required in the URL or POST body. |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
"href": "/api/resourcelink"
"cluster": {
"name": "cluster1",
"cron": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"interval": "P1DT2H3M4S",
"name": "string",
"type": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
name |
string |
Cluster name |
uuid |
string |
Cluster UUID |
cron
days |
array[integer] |
The days of the month the schedule runs. Leave empty for all. |
hours |
array[integer] |
The hours of the day the schedule runs. Leave empty for all. |
minutes |
array[integer] |
The minutes the schedule runs. Required on POST for a cron schedule. |
months |
array[integer] |
The months of the year the schedule runs. Leave empty for all. |
weekdays |
array[integer] |
The weekdays the schedule runs. Leave empty for all. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
