REST API reference
Retrieve the environment sensors for a node
Accesses the environment sensors for a node to monitor and manage sensor data effectively. This helps you ensure optimal environmental conditions for your system's operation.
HTTP method and endpoint
GET /cluster/sensors/{node.uuid}/{index}
Introduced in
ONTAP 9.11
Usage notes
Retrieve Environment Sensors
index
string
path
True
Filter by index
node.uuid
string
path
True
Filter by node.uuid
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
critical_high_threshold
integer
Value above which the sensor goes into a critically high state.
critical_low_threshold
integer
Value below which the sensor goes into a critically low state.
discrete_state
string
Used to determine whether the sensor is in a normal state or any other failed state based on the value of "discrete_value" field. This field is only applicable for discrete sensors.
discrete_value
string
Applies to discrete sensors which do not have an integer value. It can have values like on, off, good, bad, ok.
index
integer
Provides the sensor ID.
name
string
Name of the sensor.
node
node
threshold_state
string
Used to determine whether the sensor is in a normal state or any other failed state.
type
string
Used to detrmine the type of the sensor.
value
integer
Provides the sensor reading.
value_units
string
Units in which the "value" is measured. Some examples of units are mV, mW*hr, C, RPM.
warning_high_threshold
integer
Value above which the sensor goes into a warning high state.
warning_low_threshold
integer
Value below which the sensor goes into a warning low state.
      "href": "/api/resourcelink"
  "critical_high_threshold": 0,
  "critical_low_threshold": 0,
  "discrete_state": "normal",
  "discrete_value": "ok",
  "index": 0,
  "name": "PVCCSA CPU FD",
  "node": {
    "name": "node1",
  "threshold_state": "normal",
  "type": "string",
  "value": 831,
  "value_units": "mV",
  "warning_high_threshold": 0,
  "warning_low_threshold": 0
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
