Retrieve the environment sensors for a node
GET /cluster/sensors/{node.uuid}/{index}
Introduced In: 9.11
Retrieve Environment Sensors
index  |
string  |
path  |
True  |
Filter by index  |
node.uuid  |
string  |
path  |
True  |
Filter by node.uuid  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
critical_high_threshold  |
integer  |
Value above which the sensor goes into a critically high state.  |
critical_low_threshold  |
integer  |
Value below which the sensor goes into a critically low state.  |
discrete_state  |
string  |
Used to determine whether the sensor is in a normal state or any other failed state based on the value of "discrete_value" field. This field is only applicable for discrete sensors.  |
discrete_value  |
string  |
Applies to discrete sensors which do not have an integer value. It can have values like on, off, good, bad, ok.  |
index  |
integer  |
Provides the sensor ID.  |
name  |
string  |
Name of the sensor.  |
node  |
threshold_state  |
string  |
Used to determine whether the sensor is in a normal state or any other failed state.  |
type  |
string  |
Used to determine the type of the sensor.  |
value  |
integer  |
Provides the sensor reading.  |
value_units  |
string  |
Units in which the "value" is measured. Some examples of units are mV, mW*hr, C, RPM.  |
warning_high_threshold  |
integer  |
Value above which the sensor goes into a warning high state.  |
warning_low_threshold  |
integer  |
Value below which the sensor goes into a warning low state.  |
      "href": "/api/resourcelink"
  "critical_high_threshold": 0,
  "critical_low_threshold": 0,
  "discrete_state": "normal",
  "discrete_value": "ok",
  "index": 0,
  "name": "PVCCSA CPU FD",
  "node": {
    "name": "node1",
  "threshold_state": "normal",
  "type": "string",
  "value": 831,
  "value_units": "mV",
  "warning_high_threshold": 0,
  "warning_low_threshold": 0
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
self_link
self  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
