Retrieve a UNIX group cache setting for an SVM
Retrieves the UNIX group cache setting for a specific SVM to understand its configuration and manage name service performance effectively.
HTTP method and endpoint
GET /name-services/cache/unix-group/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a unix-group cache setting for a given SVM.
Related ONTAP commands
vserver services name-service cache unix-group settings show
Learn more
svm.uuid |
string |
path |
True |
SVM UUID. |
enabled |
boolean |
query |
False |
Filter by enabled |
propagation_enabled |
boolean |
query |
False |
Filter by propagation_enabled |
svm.name |
string |
query |
False |
Filter by svm.name |
negative_ttl |
string |
query |
False |
Filter by negative_ttl |
ttl |
string |
query |
False |
Filter by ttl |
negative_cache_enabled |
boolean |
query |
False |
Filter by negative_cache_enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
boolean |
Specifies whether the propagation setting is enabled or not. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
"href": "/api/resourcelink"
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
