REST API reference
Retrieve a UNIX group cache setting for an SVM
Retrieves a UNIX group cache setting for a specified SVM to manage and configure cache settings for UNIX groups effectively.
HTTP method and endpoint
GET /name-services/cache/unix-group/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a unix-group cache setting for a given SVM.
  • vserver services name-service cache unix-group settings show
svm.uuid
string
path
True
SVM UUID.
ttl
string
query
False
Filter by ttl
enabled
boolean
query
False
Filter by enabled
negative_cache_enabled
boolean
query
False
Filter by negative_cache_enabled
svm.name
string
query
False
Filter by svm.name
negative_ttl
string
query
False
Filter by negative_ttl
propagation_enabled
boolean
query
False
Filter by propagation_enabled
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
Indicates whether or not the cache is enabled.
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
propagation_enabled
boolean
Specifies whether the propagation setting is enabled or not.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
      "href": "/api/resourcelink"
  "negative_ttl": "PT5M",
  "svm": {
    "name": "svm1",
  "ttl": "PT24H"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
