Display HTTP proxy server, port, and IPspace information for an SVM or cluster IPspace
GET /network/http-proxy/{uuid}
Introduced In: 9.7
Displays the HTTP proxy server, port, and IPspace of the specified SVM or Cluster IPspace.
Related ONTAP commands
vserver http-proxy show
Name | Type | In | Required | Description |
uuid |
string |
path |
True |
HTTP proxy UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
Name | Type | Description |
_links |
authentication_enabled |
boolean |
Specifies whether or not authentication with the HTTP proxy server is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. This is mutually exclusive with SVM during POST and PATCH. |
port |
integer |
The port number on which the HTTP proxy service is configured on the proxy server. |
scope |
string |
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster". |
server |
string |
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server. |
svm |
This is mutually exclusive with IPspace during POST and PATCH. |
uuid |
string |
The UUID that uniquely identifies the HTTP proxy. |
"href": "/api/resourcelink"
"ipspace": {
"name": "Default",
"port": 3128,
"scope": "string",
"server": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
