REST API reference
Display HTTP proxy server, port, and IPspace information for an SVM or cluster IPspace
GET /network/http-proxy/{uuid}
Introduced In: 9.7
Displays the HTTP proxy server, port, and IPspace of the specified SVM or Cluster IPspace.
  • vserver http-proxy show
uuid
string
path
True
HTTP proxy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_enabled
boolean
Specifies whether or not authentication with the HTTP proxy server is enabled.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. This is mutually exclusive with SVM during POST and PATCH.
port
integer
The port number on which the HTTP proxy service is configured on the proxy server.
scope
string
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster".
server
string
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server.
svm
svm
This is mutually exclusive with IPspace during POST and PATCH.
uuid
string
The UUID that uniquely identifies the HTTP proxy.
      "href": "/api/resourcelink"
  "ipspace": {
    "name": "Default",
  "port": 3128,
  "scope": "string",
  "server": "string",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
