REST API reference
Retrieve IPspaces for a cluster
GET /network/ipspaces
Introduced In: 9.6
Retrieves a collection of IPspaces for the entire cluster.
  • network ipspace show
name
string
query
False
Filter by name
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[ipspace]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "ipspace1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
The UUID that uniquely identifies the IPspace.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
