REST API reference
Retrieve IPspaces for a cluster
Retrieves IPspaces for a cluster to access the network configurations associated with the entire cluster. This is useful for managing and reviewing the network segmentation and isolation settings in your environment.
HTTP method and endpoint
GET /network/ipspaces
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of IPspaces for the entire cluster.
  • network ipspace show
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
tcp_stack
string
query
False
Filter by tcp_stack
  • Introduced in: 9.19
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[ipspace]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "ipspace1",
      "tcp_stack": "freebsd",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
_links
_links
name
string
IPspace name
tcp_stack
string
The TCP stack used by the IPspace.
uuid
string
The UUID that uniquely identifies the IPspace.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
