REST API reference
Retrieve applied restricted group policies for an SVM
Retrieves the restricted group policies that are applied to a specified SVM to review the current access restrictions in place.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/restricted-groups
Introduced in
ONTAP 9.12
Usage notes
Retrieves applied policies of restricted groups for specified SVM.
  • vserver cifs group-policy restricted-group show-applied
memberships
string
query
False
Filter by memberships
svm.name
string
query
False
Filter by svm.name
group_name
string
query
False
Filter by group_name
  • minLength: 1
policy_name
string
query
False
Filter by policy_name
  • minLength: 1
members
string
query
False
Filter by members
link
string
query
False
Filter by link
version
integer
query
False
Filter by version
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of restricted group info.
records
array[group_policy_object_restricted_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "group_name": "test_group",
      "link": "domain",
      "members": [
        "DOMAIN/test_user",
        "DOMAIN/user2"
      "memberships": [
        "DOMAIN/AdministratorGrp",
        "DOMAIN/deptMark"
      "policy_name": "test_policy",
      "svm": {
        "name": "svm1",
      "version": 7
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
Will not be populated for objects that are yet to be applied.
_links
_links
name
string
uuid
string
group_name
string
link
string
Link info.
members
array[string]
Members of the group.
memberships
array[string]
Group is member of Group/OU.
policy_name
string
svm
svm
version
integer
Group policy object version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
