REST API reference
Retrieve applied restricted group policies for an SVM
Retrieves the applied restricted group policies for a specified SVM to manage and review the group's access controls.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/restricted-groups
Introduced in
ONTAP 9.12
Usage notes
Retrieves applied policies of restricted groups for specified SVM.
  • vserver cifs group-policy restricted-group show-applied
group_name
string
query
False
Filter by group_name
  • minLength: 1
link
string
query
False
Filter by link
members
string
query
False
Filter by members
memberships
string
query
False
Filter by memberships
version
integer
query
False
Filter by version
svm.name
string
query
False
Filter by svm.name
policy_name
string
query
False
Filter by policy_name
  • minLength: 1
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of restricted group info.
records
array[group_policy_object_restricted_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "group_name": "test_group",
      "link": "domain",
      "members": [
        "DOMAIN/test_user",
        "DOMAIN/user2"
      "memberships": [
        "DOMAIN/AdministratorGrp",
        "DOMAIN/deptMark"
      "policy_name": "test_policy",
      "svm": {
        "name": "svm1",
      "version": 7
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
Will not be populated for objects that are yet to be applied.
_links
_links
name
string
uuid
string
group_name
string
link
string
Link info.
members
array[string]
Members of the group.
memberships
array[string]
Group is member of Group/OU.
policy_name
string
svm
svm
version
integer
Group policy object version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
