Retrieve the NDMP node configurations for all nodes
Retrieves NDMP node configurations for all nodes to access and review the NDMP settings across your ONTAP environment.
HTTP method and endpoint
GET /protocols/ndmp/nodes
Introduced in
ONTAP 9.7
Usage notes
Retrieves NDMP node configurations for all of the nodes.
Related ONTAP commands
system services ndmp show
Learn more
enabled |
boolean |
query |
False |
Filter by enabled |
user |
string |
query |
False |
Filter by user |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
authentication_types |
string |
query |
False |
Filter by authentication_types |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[ndmp_node] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"authentication_types": [
"plaintext",
"challenge"
"enabled": 1,
"node": {
"name": "node1",
"user": "ndmp_user"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812801 |
Node-scoped operations are not allowed in an SVM-scope. |
68812804 |
Failed to get the node name from the specified node UUID. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
Storage system node
_links |
name |
string |
uuid |
string |
ndmp_node
_links |
array[string] |
NDMP authentication types. |
enabled |
boolean |
Is the NDMP service enabled? |
node |
Storage system node |
user |
string |
NDMP user ID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
