REST API reference
Retrieve the NDMP node configurations for all nodes
GET /protocols/ndmp/nodes
Introduced In: 9.7
Retrieves NDMP node configurations for all of the nodes.
  • system services ndmp show
enabled
boolean
query
False
Filter by enabled
authentication_types
string
query
False
Filter by authentication_types
user
string
query
False
Filter by user
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[ndmp_node]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_types": [
        "plaintext",
        "challenge"
      "enabled": 1,
      "node": {
        "name": "node1",
      "user": "ndmp_user"
Status: Default
ONTAP Error Response codes
Error code Description
68812801
Node-scoped operations are not allowed in an SVM-scope.
68812804
Failed to get the node name from the specified node UUID.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
Storage system node
_links
_links
name
string
uuid
string
ndmp_node
_links
_links
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled?
node
node
Storage system node
user
string
NDMP user ID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
