REST API reference
Retrieve NDMP configuration for an SVM
Retrieves the NDMP configuration for a specific SVM to review or verify the current settings related to NDMP operations.
HTTP method and endpoint
GET /protocols/ndmp/svms/{svm.uuid}
Introduced in
ONTAP 9.7
  • vserver services ndmp show
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_types
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled on the SVM?
svm
svm
      "href": "/api/resourcelink"
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response codes
Error code Description
2
The UUID provided is an invalid value for field "svm.uuid".
262197
The value provided is invalid for field "fields".
65601536
The operation is not supported because NDMP SVM-aware mode is disabled.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
