REST API reference
Retrieve the NDMP configuration for an SVM
Retrieves the NDMP configuration for an SVM to view or manage its backup settings and ensure data protection processes are correctly configured.
HTTP method and endpoint
GET /protocols/ndmp/svms/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves an NDMP configuration for a specific SVM.
  • vserver services ndmp show
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_types
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled on the SVM?
svm
svm
      "href": "/api/resourcelink"
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
