REST API reference
Manage NDMP configuration of SVM
Manage NDMP configurations of your SVMs using these endpoints to adjust settings such as authentication types and enabled status.
You can use this API to manage NDMP configurations of SVMs.
Updates the "enabled" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"enabled":"false"}'
Updates the "authentication_types" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"authentication_types":["challenge"]}'
