REST API reference
Manage NDMP configuration of SVM
Use the NDMP configuration endpoints to manage the NDMP settings of SVMs within your environment. These endpoints enable adjustments to fields like "enabled" and "authentication_types" for tailored data management solutions.
You can use this API to manage NDMP configurations of SVMs.
Updates the "enabled" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"enabled":"false"}'
Updates the "authentication_types" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"authentication_types":["challenge"]}'
