Manage NDMP configuration of SVM
Use this API to manage NDMP configurations for your SVMs. Adjust settings such as enabling NDMP or modifying authentication types to support your data management needs.
You can use this API to manage NDMP configurations of SVMs.
Updates the "enabled" field:
PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"enabled":"false"}'
Updates the "authentication_types" field:
PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"authentication_types":["challenge"]}'
