REST API reference
Manage NDMP configuration of SVM
Manage NDMP configurations of SVMs using these endpoints to tailor data protection settings. Configure fields such as "enabled" and "authentication_types" to optimize your backup operations.
You can use this API to manage NDMP configurations of SVMs.
Updates the "enabled" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"enabled":"false"}'
Updates the "authentication_types" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"authentication_types":["challenge"]}'
