Retrieve an NFS over TLS interface configuration
Retrieves the configuration of an NFS over TLS interface to review its current settings for secure data transmission.
HTTP method and endpoint
GET /protocols/nfs/tls/interfaces/{interface.uuid}
Introduced in
ONTAP 9.15
Usage notes
Retrieves an NFS over TLS interface.
Related ONTAP commands
vserver nfs tls interface show
Learn more
interface.uuid |
string |
path |
True |
Network interface UUID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Specifies the certificate that is used for creating NFS over TLS connections. |
enabled |
boolean |
Indicates whether NFS over TLS is enabled. |
interface |
Network interface. |
svm |
"href": "/api/resourcelink"
"certificate": {
"name": "string",
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Network interface.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
