REST API reference
Retrieve an NFS over TLS interface configuration
Accesses the configuration details of an NFS over TLS interface to review the current settings for secure NFS communication.
HTTP method and endpoint
GET /protocols/nfs/tls/interfaces/{interface.uuid}
Introduced in
ONTAP 9.15
Usage notes
Retrieves an NFS over TLS interface.
  • vserver nfs tls interface show
interface.uuid
string
path
True
Network interface UUID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
Specifies the certificate that is used for creating NFS over TLS connections.
enabled
boolean
Indicates whether NFS over TLS is enabled.
interface
interface
Network interface.
svm
svm
      "href": "/api/resourcelink"
  "certificate": {
    "name": "string",
  "interface": {
    "ip": {
      "address": "10.10.10.7"
    "name": "lif1",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response codes
Error codes Description
262197
The value provided is invalid for field "fields".
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
Network interface.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
