REST API reference
Retrieve NFS over TLS interface configurations
Retrieves configurations for NFS over TLS interfaces to understand and manage secure NFS communication settings.
HTTP method and endpoint
GET /protocols/nfs/tls/interfaces
Introduced in
ONTAP 9.15
Usage notes
Retrieves NFS over TLS interfaces.
  • vserver nfs tls interface show
enabled
boolean
query
False
Filter by enabled
interface.ip.address
string
query
False
Filter by interface.ip.address
interface.name
string
query
False
Filter by interface.name
interface.uuid
string
query
False
Filter by interface.uuid
certificate.uuid
string
query
False
Filter by certificate.uuid
certificate.name
string
query
False
Filter by certificate.name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[nfs_tls_interface]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "certificate": {
        "name": "string",
      "interface": {
        "ip": {
          "address": "10.10.10.7"
        "name": "lif1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
certificate
Specifies the certificate that is used for creating NFS over TLS connections.
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
Network interface.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
svm
_links
_links
name
string
uuid
string
nfs_tls_interface
_links
_links
certificate
certificate
enabled
boolean
Indicates whether NFS over TLS is enabled.
interface
interface
Network interface.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
