Retrieve NFS over TLS interface configurations
Retrieves NFS over TLS interface configurations to access detailed information about current network settings that support secure communication. This helps ensure your data is transmitted securely within your storage environment.
HTTP method and endpoint
GET /protocols/nfs/tls/interfaces
Introduced in
ONTAP 9.15
Usage notes
Retrieves NFS over TLS interfaces.
Related ONTAP commands
vserver nfs tls interface show
Learn more
certificate.name |
string |
query |
False |
Filter by certificate.name |
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
interface.name |
string |
query |
False |
Filter by interface.name |
interface.ip.address |
string |
query |
False |
Filter by interface.ip.address |
enabled |
boolean |
query |
False |
Filter by enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nfs_tls_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"certificate": {
"name": "string",
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
Specifies the certificate that is used for creating NFS over TLS connections.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Network interface.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
_links |
name |
string |
uuid |
string |
nfs_tls_interface
_links |
certificate |
Specifies the certificate that is used for creating NFS over TLS connections. |
enabled |
boolean |
Indicates whether NFS over TLS is enabled. |
interface |
Network interface. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
