REST API reference
Retrieve an NVMe subsystem host
Retrieves an NVMe subsystem host to access the configuration and details specific to that host within an NVMe subsystem.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an NVMe subsystem host of an NVMe subsystem.
  • vserver nvme subsystem host show
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
nqn
string
path
True
The NVMe qualified name (NQN) used to identify the NVMe subsystem host.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
dh_hmac_chap
dh_hmac_chap
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol.
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
priority
string
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used.
subsystem
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
      "href": "/api/resourcelink"
  "dh_hmac_chap": {
    "group_size": "string",
    "hash_function": "string",
    "mode": "bidirectional"
  "io_queue": {
    "count": 4,
    "depth": 32
  "nqn": "nqn.1992-01.example.com:string",
  "priority": "string",
  "subsystem": {
    "name": "subsystem1",
Status: Default
ONTAP Error Response Codes
Error Code Description
72090001
The NVMe subsystem does not exist.
72090004
The NVMe subsystem host does not exist.
72090022
The NVMe subsystem host does not exist in the specified subsystem.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
dh_hmac_chap
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
io_queue
count
integer
The number of I/O queue pairs. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue count is being used. Valid in GET only.
depth
integer
The I/O queue depth. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue depth is being used. Valid in GET only.
io_queue
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links
_links
dh_hmac_chap
dh_hmac_chap
io_queue
io_queue
nqn
string
subsystem
subsystem
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
