REST API reference
Retrieve an NVMe subsystem host
Retrieves details about an NVMe subsystem host, which can help you understand its configuration within the NVMe subsystem.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an NVMe subsystem host of an NVMe subsystem.
  • vserver nvme subsystem host show
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
nqn
string
path
True
The NVMe qualified name (NQN) used to identify the NVMe subsystem host.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
subsystem
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
      "href": "/api/resourcelink"
  "io_queue": {
    "count": "4",
    "depth": "32"
  "nqn": "nqn.1992-01.example.com:string",
  "subsystem": {
Status: Default
ONTAP Error Response Codes
Error Code Description
72090001
The NVMe subsystem does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
io_queue
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
_links
_links
uuid
string
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links
_links
io_queue
io_queue
nqn
string
subsystem
subsystem
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
