Retrieve a portset
GET /protocols/san/portsets/{uuid}
Introduced In: 9.9
Retrieves a portset.
Related ONTAP commands
lun portset show
Learn more
uuid |
string |
path |
True |
The unique identifier of the portset. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
igroups |
array[igroups] |
An array initiator groups to which the portset is bound. |
interfaces |
array[interfaces] |
An array of network interfaces that are members of the portset. These are the only network interfaces through which the initiators of a bound igroup can access mapped LUNs. Zero or more network interfaces can be supplied when the portset is created. After creation, network interfaces can be added or removed from the portset using the |
name |
string |
The name of the portset. Required in POST. The name of a portset cannot be changed after creation. |
protocol |
string |
The protocols supported by the portset. This restricts the type of network interfaces that can be added to the portset. Optional in POST; if not supplied, this defaults to mixed. The protocol of a portset cannot be changed after creation. |
svm |
uuid |
string |
The unique identifier for a portset. |
"href": "/api/resourcelink"
"igroups": [
"name": "igroup1",
"interfaces": [
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"name": "portset1",
"protocol": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The portset does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
igroups
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
fc
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
ip
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
interfaces
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links |
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
uuid |
string |
The unique identifier of the network interface. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
