REST API reference
Retrieve a portset
GET /protocols/san/portsets/{uuid}
Introduced In: 9.9
Retrieves a portset.
  • lun portset show
uuid
string
path
True
The unique identifier of the portset.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
igroups
array[igroups]
An array initiator groups to which the portset is bound.
interfaces
array[interfaces]
An array of network interfaces that are members of the portset. These are the only network interfaces through which the initiators of a bound igroup can access mapped LUNs.
Zero or more network interfaces can be supplied when the portset is created. After creation, network interfaces can be added or removed from the portset using the /protocols/san/portsets/{portset.uuid}/interfaces endpoint. See link:post-protocols-san-portsets-interfaces_-san-portset-interface-create_anddelete-protocols-san-portsets-interfaces-.htmlPOST /protocols/san/portsets/{portset.uuid}/interfaces and [DELETE /protocols/san/portsets/{portset.uuid}/interfaces/{uuid}] for more details.
name
string
The name of the portset. Required in POST.
The name of a portset cannot be changed after creation.
protocol
string
The protocols supported by the portset. This restricts the type of network interfaces that can be added to the portset. Optional in POST; if not supplied, this defaults to mixed.
The protocol of a portset cannot be changed after creation.
svm
svm
uuid
string
The unique identifier for a portset.
      "href": "/api/resourcelink"
  "igroups": [
      "name": "igroup1",
  "interfaces": [
      "fc": {
        "name": "fc_lif1",
        "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
        "wwpn": "20:00:00:50:56:b4:13:a8"
      "ip": {
        "ip": {
          "address": "10.10.10.7"
        "name": "lif1",
  "name": "portset1",
  "protocol": "string",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The portset does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
igroups
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
fc
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
address
string
IPv4 or IPv6 address
ip
A network interface. Either UUID or name may be supplied on input.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interfaces
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links
_links
fc
fc
An FC interface.
ip
ip
uuid
string
The unique identifier of the network interface.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
