Retrieve the LDAP configuration for the cluster
GET /security/authentication/cluster/ldap
Introduced In: 9.6
Retrieves the cluster LDAP configuration.
Related ONTAP commands
ldap show -
ldap check -vserver vs0 -
ldap check-ipv6 -vserver vs0
Important notes
The status.code, status.dn_message, status.message, and status.state fields have the same status fields that are returned using the "ldap check" CLI command.
Refer to the ipv4 or ipv6 objects available in the status field to get specific information about the code, dn_messages, or message and state information for ipv4 or ipv6.
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
base_dn  |
string  |
Specifies the default base DN for all searches.  |
base_scope  |
string  |
Specifies the default search scope for LDAP queries:
bind_as_cifs_server  |
boolean  |
Specifies whether or not CIFS server's credentials are used to bind to the LDAP server.  |
bind_dn  |
string  |
Specifies the user that binds to the LDAP servers.  |
group_dn  |
string  |
Specifies the group Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for group lookups.  |
group_membership_filter  |
string  |
Specifies the custom filter used for group membership lookups from an LDAP server.  |
group_scope  |
string  |
Specifies the default search scope for LDAP for group lookups:
is_netgroup_byhost_enabled  |
boolean  |
Specifies whether or not netgroup by host querying is enabled.  |
is_owner  |
boolean  |
Specifies whether or not the SVM owns the LDAP client configuration.  |
ldaps_enabled  |
boolean  |
Specifies whether or not LDAPS is enabled.  |
min_bind_level  |
string  |
The minimum bind authentication level. Possible values are:
netgroup_byhost_dn  |
string  |
Specifies the netgroup Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for netgroup by host lookups.  |
netgroup_byhost_scope  |
string  |
Specifies the default search scope for LDAP for netgroup by host lookups:
netgroup_dn  |
string  |
Specifies the netgroup Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for netgroup lookups.  |
netgroup_scope  |
string  |
Specifies the default search scope for LDAP for netgroup lookups:
port  |
integer  |
The port used to connect to the LDAP Servers.  |
query_timeout  |
integer  |
Specifies the maximum time to wait for a query response from the LDAP server, in seconds.  |
schema  |
string  |
The name of the schema template used by the SVM.
servers  |
array[string]  |
session_security  |
string  |
Specifies the level of security to be used for LDAP communications:
status  |
try_channel_binding  |
boolean  |
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.  |
use_start_tls  |
boolean  |
Specifies whether or not to use Start TLS over LDAP connections.  |
user_dn  |
string  |
Specifies the user Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for user lookups.  |
user_scope  |
string  |
Specifies the default search scope for LDAP for user lookups:
      "href": "/api/resourcelink"
  "base_dn": "string",
  "base_scope": "string",
  "bind_dn": "string",
  "group_dn": "string",
  "group_membership_filter": "string",
  "group_scope": "string",
  "min_bind_level": "string",
  "netgroup_byhost_dn": "string",
  "netgroup_byhost_scope": "string",
  "netgroup_dn": "string",
  "netgroup_scope": "string",
  "port": 389,
  "schema": "string",
  "servers": [
    "string"
  "session_security": "string",
  "skip_config_validation": true,
  "status": {
    "code": 65537300,
    "dn_message": [
      "string"
    "ipv4": {
      "code": 65537300,
      "dn_messages": [
        "string"
      "message": "string",
      "state": "string"
    "ipv4_state": "string",
    "ipv6": {
      "code": 65537300,
      "dn_messages": [
        "string"
      "state": "string"
    "ipv6_state": "string",
    "state": "string"
  "user_dn": "string",
  "user_scope": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ipv4
code  |
integer  |
Code corresponding to the error message. If there is no error, it is 0 to indicate success.  |
dn_messages  |
array[string]  |
message  |
string  |
Provides additional details on the error.  |
state  |
string  |
Status of the LDAP service.  |
ipv6
code  |
integer  |
dn_messages  |
array[string]  |
message  |
string  |
state  |
string  |
status
code  |
integer  |
This field is no longer supported. Use ipv4.code or ipv6.code instead.  |
dn_message  |
array[string]  |
ipv4  |
ipv4_state  |
string  |
This field is no longer supported. Use ipv4.state instead.  |
ipv6  |
ipv6_state  |
string  |
This field is no longer supported. Use ipv6.state instead.  |
message  |
string  |
This field is no longer supported. Use ipv4.message or ipv6.message instead.  |
state  |
string  |
The status of the LDAP service for the SVM. The LDAP service is up if either   |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
