REST API reference
Retrieve the LDAP configuration for the cluster
Retrieves the cluster's LDAP configuration to examine or verify its settings. This is useful when you need to ensure the LDAP configuration aligns with your authentication requirements.
HTTP method and endpoint
GET /security/authentication/cluster/ldap
Introduced in
ONTAP 9.6
Usage notes
Retrieves the cluster LDAP configuration.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
base_dn
string
Specifies the default base DN for all searches.
base_scope
string
Specifies the default search scope for LDAP queries:
  • base - search the named entry only
  • onelevel - search all entries immediately below the DN
  • subtree - search the named DN entry and the entire subtree below the DN
bind_as_cifs_server
boolean
Specifies whether or not CIFS server's credentials are used to bind to the LDAP server.
bind_dn
string
Specifies the user that binds to the LDAP servers.
group_dn
string
Specifies the group Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for group lookups.
group_membership_filter
string
Specifies the custom filter used for group membership lookups from an LDAP server.
group_scope
string
Specifies the default search scope for LDAP for group lookups:
is_netgroup_byhost_enabled
boolean
Specifies whether or not netgroup by host querying is enabled.
is_owner
boolean
Specifies whether or not the SVM owns the LDAP client configuration.
ldaps_enabled
boolean
Specifies whether or not LDAPS is enabled.
min_bind_level
string
The minimum bind authentication level. Possible values are:
  • anonymous - anonymous bind
  • simple - simple bind
  • sasl - Simple Authentication and Security Layer (SASL) bind
netgroup_byhost_dn
string
Specifies the netgroup Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for netgroup by host lookups.
netgroup_byhost_scope
string
Specifies the default search scope for LDAP for netgroup by host lookups:
netgroup_dn
string
Specifies the netgroup Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for netgroup lookups.
netgroup_scope
string
Specifies the default search scope for LDAP for netgroup lookups:
port
integer
The port used to connect to the LDAP Servers.
query_timeout
integer
Specifies the maximum time to wait for a query response from the LDAP server, in seconds.
schema
string
The name of the schema template used by the SVM.
  • AD-IDMU - Active Directory Identity Management for UNIX
  • AD-SFU - Active Directory Services for UNIX
  • MS-AD-BIS - Active Directory Identity Management for UNIX
  • RFC-2307 - Schema based on RFC 2307
  • Custom schema
servers
array[string]
session_security
string
Specifies the level of security to be used for LDAP communications:
  • none - no signing or sealing
  • sign - sign LDAP traffic
  • seal - seal and sign LDAP traffic
status
status
try_channel_binding
boolean
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.
use_start_tls
boolean
Specifies whether or not to use Start TLS over LDAP connections.
user_dn
string
Specifies the user Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for user lookups.
user_scope
string
Specifies the default search scope for LDAP for user lookups:
      "href": "/api/resourcelink"
  "base_dn": "string",
  "base_scope": "string",
  "bind_dn": "string",
  "group_dn": "string",
  "group_membership_filter": "string",
  "group_scope": "string",
  "min_bind_level": "string",
  "netgroup_byhost_dn": "string",
  "netgroup_byhost_scope": "string",
  "netgroup_dn": "string",
  "netgroup_scope": "string",
  "port": 389,
  "schema": "string",
  "servers": [
    "string"
  "session_security": "string",
  "skip_config_validation": true,
  "status": {
    "code": 65537300,
    "dn_message": [
      "string"
    "ipv4_state": "string",
    "ipv6_state": "string",
    "message": "string",
    "state": "string"
  "user_dn": "string",
  "user_scope": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
status
code
integer
Code corresponding to the error message. If there is no error, it will be 0 to indicate success.
dn_message
array[string]
ipv4_state
string
The status of the LDAP service with IPv4 address.
ipv6_state
string
The status of the LDAP service with IPv6 address.
message
string
Provides additional details on the error if ipv4_state or ipv6_state is down. If both ipv4_state and ipv6_state are up, it provides details of the IP addresses that are connected successfully.
state
string
The status of the LDAP service for the SVM. The LDAP service is up if either ipv4_state or ipv6_state is up. The LDAP service is down if both ipv4_state and ipv6_state are down.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
