Retrieve the LDAP configuration for the cluster
GET /security/authentication/cluster/ldap
Retrieves the cluster LDAP configuration.
Learn more
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
desc] direction. Default direction is 'asc' for ascending.  |
fields  |
array[string]  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
_links  |
base_dn  |
string  |
Specifies the default base DN for all searches.  |
base_scope  |
string  |
Specifies the default search scope for LDAP queries:
bind_dn  |
string  |
Specifies the user that binds to the LDAP servers.  |
min_bind_level  |
string  |
The minimum bind authentication level. Possible values are:
port  |
integer  |
The port used to connect to the LDAP Servers.  |
schema  |
string  |
The name of the schema template used by the SVM.
servers  |
array[string]  |
session_security  |
string  |
Specifies the level of security to be used for LDAP communications:
use_start_tls  |
boolean  |
Specifies whether or not to use Start TLS over LDAP connections.  |
      "href": "/api/resourcelink"
  "base_dn": "string",
  "base_scope": "string",
  "bind_dn": "string",
  "min_bind_level": "string",
  "port": 389,
  "schema": "string",
  "servers": [
    "string"
  "session_security": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
