Retrieve an IPsec configuration
Retrieves the IPsec configuration to review the current security settings for your network traffic.
HTTP method and endpoint
GET /security/ipsec
Introduced in
ONTAP 9.8
Usage notes
Retrieves IPsec configuration via REST APIs.
Related ONTAP commands
'security ipsec config show'
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
Indicates whether or not IPsec is enabled. |
replay_window |
integer |
Replay window size in packets, where 0 indicates that the relay window is disabled. |
"href": "/api/resourcelink"
"replay_window": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
