REST API reference
Retrieve an IPsec configuration
Retrieves the IPsec configuration to review the current security settings for your network traffic.
HTTP method and endpoint
GET /security/ipsec
Introduced in
ONTAP 9.8
Usage notes
Retrieves IPsec configuration via REST APIs.
  • 'security ipsec config show'
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
enabled
boolean
Indicates whether or not IPsec is enabled.
offload_enabled
boolean
Indicates whether or not IPsec hardware offload is enabled.
replay_window
integer
Replay window size in packets, where 0 indicates that the relay window is disabled.
      "href": "/api/resourcelink"
  "replay_window": 0
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
