Retrieve a collection of bridges
Retrieves a collection of bridges to view their configurations and statuses, which is useful for managing and monitoring bridge connections in your storage environment.
HTTP method and endpoint
GET /storage/bridges
Introduced in
ONTAP 9.9
Related ONTAP commands
storage bridge show
Learn more
errors.severity |
string |
query |
False |
Filter by errors.severity |
errors.type |
string |
query |
False |
Filter by errors.type |
errors.component.unique_id |
string |
query |
False |
Filter by errors.component.unique_id |
errors.component.id |
integer |
query |
False |
Filter by errors.component.id |
errors.component.name |
string |
query |
False |
Filter by errors.component.name |
errors.reason.arguments.code |
string |
query |
False |
Filter by errors.reason.arguments.code
errors.reason.arguments.message |
string |
query |
False |
Filter by errors.reason.arguments.message
errors.reason.code |
string |
query |
False |
Filter by errors.reason.code |
errors.reason.message |
string |
query |
False |
Filter by errors.reason.message |
vendor |
string |
query |
False |
Filter by vendor |
chassis_throughput_state |
string |
query |
False |
Filter by chassis_throughput_state |
dram_single_bit_error_count |
integer |
query |
False |
Filter by dram_single_bit_error_count |
last_reboot.reason.arguments.code |
string |
query |
False |
Filter by last_reboot.reason.arguments.code
last_reboot.reason.arguments.message |
string |
query |
False |
Filter by last_reboot.reason.arguments.message
last_reboot.reason.code |
string |
query |
False |
Filter by last_reboot.reason.code |
last_reboot.reason.message |
string |
query |
False |
Filter by last_reboot.reason.message |
last_reboot.time |
string |
query |
False |
Filter by last_reboot.time |
sas_ports.cable.technology |
string |
query |
False |
Filter by sas_ports.cable.technology |
sas_ports.cable.part_number |
string |
query |
False |
Filter by sas_ports.cable.part_number |
sas_ports.cable.serial_number |
string |
query |
False |
Filter by sas_ports.cable.serial_number |
sas_ports.cable.vendor |
string |
query |
False |
Filter by sas_ports.cable.vendor |
sas_ports.wwn |
string |
query |
False |
Filter by sas_ports.wwn |
sas_ports.phy_4.state |
string |
query |
False |
Filter by sas_ports.phy_4.state |
sas_ports.phy_2.state |
string |
query |
False |
Filter by sas_ports.phy_2.state |
sas_ports.enabled |
boolean |
query |
False |
Filter by sas_ports.enabled |
sas_ports.phy_3.state |
string |
query |
False |
Filter by sas_ports.phy_3.state |
sas_ports.state |
string |
query |
False |
Filter by sas_ports.state |
sas_ports.id |
integer |
query |
False |
Filter by sas_ports.id |
sas_ports.negotiated_data_rate |
number |
query |
False |
Filter by sas_ports.negotiated_data_rate |
sas_ports.data_rate_capability |
number |
query |
False |
Filter by sas_ports.data_rate_capability |
sas_ports.phy_1.state |
string |
query |
False |
Filter by sas_ports.phy_1.state |
paths.source_port.id |
string |
query |
False |
Filter by paths.source_port.id |
paths.source_port.name |
string |
query |
False |
Filter by paths.source_port.name |
paths.name |
string |
query |
False |
Filter by paths.name |
paths.node.uuid |
string |
query |
False |
Filter by paths.node.uuid |
paths.node.name |
string |
query |
False |
Filter by paths.node.name |
paths.target_port.name |
string |
query |
False |
Filter by paths.target_port.name |
paths.target_port.id |
string |
query |
False |
Filter by paths.target_port.id |
paths.target_port.wwn |
string |
query |
False |
Filter by paths.target_port.wwn |
state |
string |
query |
False |
Filter by state |
security_enabled |
boolean |
query |
False |
Filter by security_enabled |
temperature_sensor.reading |
integer |
query |
False |
Filter by temperature_sensor.reading |
temperature_sensor.minimum |
integer |
query |
False |
Filter by temperature_sensor.minimum |
temperature_sensor.name |
string |
query |
False |
Filter by temperature_sensor.name |
temperature_sensor.maximum |
integer |
query |
False |
Filter by temperature_sensor.maximum |
temperature_sensor.state |
string |
query |
False |
Filter by temperature_sensor.state |
wwn |
string |
query |
False |
Filter by wwn |
ip_address |
string |
query |
False |
Filter by ip_address |
serial_number |
string |
query |
False |
Filter by serial_number |
firmware_version |
string |
query |
False |
Filter by firmware_version |
model |
string |
query |
False |
Filter by model |
power_supply_units.name |
string |
query |
False |
Filter by power_supply_units.name |
power_supply_units.state |
string |
query |
False |
Filter by power_supply_units.state |
symbolic_name |
string |
query |
False |
Filter by symbolic_name |
monitoring_enabled |
boolean |
query |
False |
Filter by monitoring_enabled |
name |
string |
query |
False |
Filter by name |
managed_by |
string |
query |
False |
Filter by managed_by |
fc_ports.wwn |
string |
query |
False |
Filter by fc_ports.wwn |
fc_ports.connection_mode |
string |
query |
False |
Filter by fc_ports.connection_mode |
fc_ports.sfp.data_rate_capability |
number |
query |
False |
Filter by fc_ports.sfp.data_rate_capability |
fc_ports.sfp.vendor |
string |
query |
False |
Filter by fc_ports.sfp.vendor |
fc_ports.sfp.serial_number |
string |
query |
False |
Filter by fc_ports.sfp.serial_number |
fc_ports.sfp.part_number |
string |
query |
False |
Filter by fc_ports.sfp.part_number |
fc_ports.enabled |
boolean |
query |
False |
Filter by fc_ports.enabled |
fc_ports.peer_wwn |
string |
query |
False |
Filter by fc_ports.peer_wwn |
fc_ports.data_rate_capability |
number |
query |
False |
Filter by fc_ports.data_rate_capability |
fc_ports.state |
string |
query |
False |
Filter by fc_ports.state |
fc_ports.negotiated_data_rate |
number |
query |
False |
Filter by fc_ports.negotiated_data_rate |
fc_ports.configured_data_rate |
number |
query |
False |
Filter by fc_ports.configured_data_rate |
fc_ports.id |
integer |
query |
False |
Filter by fc_ports.id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[storage_bridge] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"chassis_throughput_state": "ok",
"errors": [
"component": {
"name": "string",
"unique_id": "string"
"reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"severity": "string",
"type": "string"
"fc_ports": [
"configured_data_rate": 0,
"connection_mode": "string",
"data_rate_capability": 2,
"negotiated_data_rate": 0,
"peer_wwn": "200650eb1a238892",
"sfp": {
"part_number": "string",
"serial_number": "string",
"vendor": "string"
"state": "string",
"wwn": "2100001086a54100"
"firmware_version": "4.10 007A",
"ip_address": "string",
"last_reboot": {
"reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"time": "2020-12-09 00:47:58 -0500"
"managed_by": "string",
"model": "FibreBridge6500N",
"name": "ATTO_FibreBridge6500N_1",
"paths": [
"name": "2c",
"node": {
"name": "node1",
"source_port": {
"id": "100050eb1a238892",
"name": "rtp-fc03-41kk11:1"
"target_port": {
"name": "rtp-fc03-41kk11:6",
"power_supply_units": [
"name": "string",
"state": "string"
"sas_ports": [
"cable": {
"technology": "string",
"vendor": "string"
"data_rate_capability": 0,
"phy_1": {
"state": "string"
"phy_2": {
"state": "string"
"phy_3": {
"state": "string"
"phy_4": {
"state": "string"
"state": "string",
"serial_number": "FB7600N100004",
"state": "string",
"symbolic_name": "rtp-fcsas03-41kk11",
"temperature_sensor": {
"name": "Chassis temperature sensor",
"state": "string"
"vendor": "atto",
"wwn": 2000001086600476
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
component
id |
integer |
Bridge error component ID |
name |
string |
Bridge error component name |
unique_id |
string |
Bridge error component unique ID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
errors
component |
reason |
severity |
string |
Bridge error severity |
type |
string |
Bridge error type |
sfp
number |
Bridge FC port SFP data rate capability, in Gbps |
part_number |
string |
serial_number |
string |
Bridge FC port SFP serial number |
vendor |
string |
Bridge FC port SFP vendor |
fc_ports
number |
Bridge FC port configured data rate, in Gbps |
connection_mode |
string |
Bridge FC port configured connection mode |
number |
Bridge FC port data rate capability, in Gbps |
enabled |
boolean |
Indicates whether the bridge FC port is enabled. |
id |
integer |
Bridge FC port index |
number |
Bridge FC port negotiated data rate, in Gbps |
peer_wwn |
string |
Bridge FC port peer port world wide name |
sfp |
state |
string |
Bridge FC port state |
wwn |
string |
Bridge FC port world wide name |
error
The error message and code explaining why the bridge rebooted.
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
last_reboot
reason |
The error message and code explaining why the bridge rebooted. |
time |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
source_port
id |
string |
Initiator side switch port id |
name |
string |
Initiator side switch port name |
target_port
id |
string |
Target side switch port id |
name |
string |
Target side switch port name |
wwn |
string |
Target side switch port world wide name |
paths
name |
string |
node |
source_port |
target_port |
power_supply_units
name |
string |
Power supply unit name |
state |
string |
Power supply unit state |
cable
part_number |
string |
Bridge cable part number |
serial_number |
string |
Bridge cable serial number |
technology |
string |
Bridge cable type |
vendor |
string |
Bridge cable vendor |
phy_1
state |
string |
Bridge SAS port PHY1 state |
phy_2
state |
string |
Bridge SAS port PHY2 state |
phy_3
state |
string |
Bridge SAS port PHY3 state |
phy_4
state |
string |
Bridge SAS port PHY4 state |
sas_ports
cable |
number |
Bridge SAS port data rate capability, in Gbps |
enabled |
boolean |
Indicates whether a bridge SAS port is enabled. |
id |
integer |
Bridge SAS port index |
number |
Bridge SAS port negotiated data rate, in Gbps |
phy_1 |
phy_2 |
phy_3 |
phy_4 |
state |
string |
Bridge SAS port state |
wwn |
string |
Bridge SAS port world wide name |
temperature_sensor
maximum |
integer |
Maximum safe operating temperature, in degrees Celsius. |
minimum |
integer |
Minimum safe operating temperature, in degrees Celsius. |
name |
string |
Temperature sensor name |
reading |
integer |
Chassis temperature sensor reading, in degrees Celsius. |
state |
string |
storage_bridge
string |
Chassis throughput status |
integer |
errors |
array[errors] |
fc_ports |
array[fc_ports] |
firmware_version |
string |
Bridge firmware version |
ip_address |
string |
IP Address |
last_reboot |
managed_by |
string |
model |
string |
Bridge model |
boolean |
Indicates whether monitoring is enabled for the bridge. |
name |
string |
Bridge name |
paths |
array[paths] |
power_supply_units |
array[power_supply_units] |
sas_ports |
array[sas_ports] |
security_enabled |
boolean |
Indicates whether security is enabled for the bridge. |
serial_number |
string |
Bridge serial number |
state |
string |
Bridge state |
symbolic_name |
string |
Bridge symbolic name |
temperature_sensor |
vendor |
string |
Bridge vendor |
wwn |
string |
Bridge world wide name |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
