REST API reference
Retrieve a collection of bridges
Retrieves information about multiple bridges, which helps you manage and configure bridge resources effectively.
HTTP method and endpoint
GET /storage/bridges
Introduced in
ONTAP 9.9
Usage notes
Retrieves a collection of bridges.
  • storage bridge show
managed_by
string
query
False
Filter by managed_by
symbolic_name
string
query
False
Filter by symbolic_name
firmware_version
string
query
False
Filter by firmware_version
serial_number
string
query
False
Filter by serial_number
last_reboot.reason.arguments.message
string
query
False
Filter by last_reboot.reason.arguments.message
  • Introduced in: 9.10
last_reboot.reason.arguments.code
string
query
False
Filter by last_reboot.reason.arguments.code
last_reboot.reason.message
string
query
False
Filter by last_reboot.reason.message
last_reboot.reason.code
string
query
False
Filter by last_reboot.reason.code
last_reboot.reason.target
string
query
False
Filter by last_reboot.reason.target
last_reboot.time
string
query
False
Filter by last_reboot.time
name
string
query
False
Filter by name
model
string
query
False
Filter by model
ip_address
string
query
False
Filter by ip_address
fc_ports.wwn
string
query
False
Filter by fc_ports.wwn
fc_ports.configured_data_rate
number
query
False
Filter by fc_ports.configured_data_rate
fc_ports.connection_mode
string
query
False
Filter by fc_ports.connection_mode
fc_ports.enabled
boolean
query
False
Filter by fc_ports.enabled
fc_ports.peer_wwn
string
query
False
Filter by fc_ports.peer_wwn
fc_ports.sfp.data_rate_capability
number
query
False
Filter by fc_ports.sfp.data_rate_capability
fc_ports.sfp.part_number
string
query
False
Filter by fc_ports.sfp.part_number
fc_ports.sfp.serial_number
string
query
False
Filter by fc_ports.sfp.serial_number
fc_ports.sfp.vendor
string
query
False
Filter by fc_ports.sfp.vendor
fc_ports.data_rate_capability
number
query
False
Filter by fc_ports.data_rate_capability
fc_ports.negotiated_data_rate
number
query
False
Filter by fc_ports.negotiated_data_rate
fc_ports.id
integer
query
False
Filter by fc_ports.id
fc_ports.state
string
query
False
Filter by fc_ports.state
wwn
string
query
False
Filter by wwn
state
string
query
False
Filter by state
paths.node.uuid
string
query
False
Filter by paths.node.uuid
paths.node.name
string
query
False
Filter by paths.node.name
paths.source_port.name
string
query
False
Filter by paths.source_port.name
paths.source_port.id
string
query
False
Filter by paths.source_port.id
paths.target_port.name
string
query
False
Filter by paths.target_port.name
paths.target_port.id
string
query
False
Filter by paths.target_port.id
paths.target_port.wwn
string
query
False
Filter by paths.target_port.wwn
paths.name
string
query
False
Filter by paths.name
temperature_sensor.minimum
integer
query
False
Filter by temperature_sensor.minimum
temperature_sensor.maximum
integer
query
False
Filter by temperature_sensor.maximum
temperature_sensor.reading
integer
query
False
Filter by temperature_sensor.reading
temperature_sensor.name
string
query
False
Filter by temperature_sensor.name
temperature_sensor.state
string
query
False
Filter by temperature_sensor.state
vendor
string
query
False
Filter by vendor
security_enabled
boolean
query
False
Filter by security_enabled
chassis_throughput_state
string
query
False
Filter by chassis_throughput_state
power_supply_units.name
string
query
False
Filter by power_supply_units.name
power_supply_units.state
string
query
False
Filter by power_supply_units.state
monitoring_enabled
boolean
query
False
Filter by monitoring_enabled
sas_ports.negotiated_data_rate
number
query
False
Filter by sas_ports.negotiated_data_rate
sas_ports.phy_2.state
string
query
False
Filter by sas_ports.phy_2.state
sas_ports.id
integer
query
False
Filter by sas_ports.id
sas_ports.state
string
query
False
Filter by sas_ports.state
sas_ports.cable.technology
string
query
False
Filter by sas_ports.cable.technology
sas_ports.cable.part_number
string
query
False
Filter by sas_ports.cable.part_number
sas_ports.cable.vendor
string
query
False
Filter by sas_ports.cable.vendor
sas_ports.cable.serial_number
string
query
False
Filter by sas_ports.cable.serial_number
sas_ports.data_rate_capability
number
query
False
Filter by sas_ports.data_rate_capability
sas_ports.phy_3.state
string
query
False
Filter by sas_ports.phy_3.state
sas_ports.wwn
string
query
False
Filter by sas_ports.wwn
sas_ports.phy_4.state
string
query
False
Filter by sas_ports.phy_4.state
sas_ports.phy_1.state
string
query
False
Filter by sas_ports.phy_1.state
sas_ports.enabled
boolean
query
False
Filter by sas_ports.enabled
dram_single_bit_error_count
integer
query
False
Filter by dram_single_bit_error_count
errors.component.unique_id
string
query
False
Filter by errors.component.unique_id
errors.component.id
integer
query
False
Filter by errors.component.id
errors.component.name
string
query
False
Filter by errors.component.name
errors.severity
string
query
False
Filter by errors.severity
errors.reason.arguments.message
string
query
False
Filter by errors.reason.arguments.message
errors.reason.arguments.code
string
query
False
Filter by errors.reason.arguments.code
errors.reason.message
string
query
False
Filter by errors.reason.message
errors.reason.code
string
query
False
Filter by errors.reason.code
errors.reason.target
string
query
False
Filter by errors.reason.target
errors.type
string
query
False
Filter by errors.type
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[storage_bridge]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "chassis_throughput_state": "ok",
      "errors": [
          "component": {
            "name": "string",
            "unique_id": "string"
          "reason": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
            "target": "uuid"
          "severity": "string",
          "type": "string"
      "fc_ports": [
          "configured_data_rate": "0",
          "connection_mode": "string",
          "data_rate_capability": "2",
          "negotiated_data_rate": "0",
          "peer_wwn": "200650eb1a238892",
          "sfp": {
            "part_number": "string",
            "serial_number": "string",
            "vendor": "string"
          "state": "string",
          "wwn": "2100001086a54100"
      "firmware_version": "4.10 007A",
      "ip_address": "string",
      "last_reboot": {
        "reason": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "target": "uuid"
        "time": "2020-12-09T00:47:58-05:00"
      "managed_by": "string",
      "model": "FibreBridge6500N",
      "name": "ATTO_FibreBridge6500N_1",
      "paths": [
          "name": "2c",
          "node": {
            "name": "node1",
          "source_port": {
            "id": "100050eb1a238892",
            "name": "rtp-fc03-41kk11:1"
          "target_port": {
            "name": "rtp-fc03-41kk11:6",
      "power_supply_units": [
          "name": "string",
          "state": "string"
      "sas_ports": [
          "cable": {
            "technology": "string",
            "vendor": "string"
          "data_rate_capability": "0",
          "phy_1": {
            "state": "string"
          "phy_2": {
            "state": "string"
          "phy_3": {
            "state": "string"
          "phy_4": {
            "state": "string"
          "state": "string",
      "serial_number": "FB7600N100004",
      "state": "string",
      "symbolic_name": "rtp-fcsas03-41kk11",
      "temperature_sensor": {
        "name": "Chassis temperature sensor",
        "state": "string"
      "vendor": "atto",
      "wwn": "2000001086600476"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
component
id
integer
Bridge error component ID
name
string
Bridge error component name
unique_id
string
Bridge error component unique ID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
errors
component
component
reason
error
severity
string
Bridge error severity
type
string
Bridge error type
sfp
number
Bridge FC port SFP data rate capability, in Gbps
part_number
string
serial_number
string
Bridge FC port SFP serial number
vendor
string
Bridge FC port SFP vendor
fc_ports
number
Bridge FC port configured data rate, in Gbps
connection_mode
string
Bridge FC port configured connection mode
number
Bridge FC port data rate capability, in Gbps
enabled
boolean
Indicates whether the bridge FC port is enabled.
id
integer
Bridge FC port index
number
Bridge FC port negotiated data rate, in Gbps
peer_wwn
string
Bridge FC port peer port world wide name
sfp
sfp
state
string
Bridge FC port state
wwn
string
Bridge FC port world wide name
error
The error message and code explaining why the bridge rebooted.
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
last_reboot
reason
error
time
string
self
node
_links
_links
name
string
uuid
string
source_port
id
string
Initiator side switch port id
name
string
Initiator side switch port name
target_port
id
string
Target side switch port id
name
string
Target side switch port name
wwn
string
Target side switch port world wide name
paths
name
string
node
node
source_port
source_port
target_port
target_port
power_supply_units
name
string
Power supply unit name
state
string
Power supply unit state
cable
part_number
string
Bridge cable part number
serial_number
string
Bridge cable serial number
technology
string
Bridge cable type
vendor
string
Bridge cable vendor
phy_1
state
string
Bridge SAS port PHY1 state
phy_2
state
string
Bridge SAS port PHY2 state
phy_3
state
string
Bridge SAS port PHY3 state
phy_4
state
string
Bridge SAS port PHY4 state
sas_ports
cable
cable
number
Bridge SAS port data rate capability, in Gbps
enabled
boolean
Indicates whether a bridge SAS port is enabled.
id
integer
Bridge SAS port index
number
Bridge SAS port negotiated data rate, in Gbps
phy_1
phy_1
phy_2
phy_2
phy_3
phy_3
phy_4
phy_4
state
string
Bridge SAS port state
wwn
string
Bridge SAS port world wide name
temperature_sensor
maximum
integer
Maximum safe operating temperature, in degrees Celsius.
minimum
integer
Minimum safe operating temperature, in degrees Celsius.
name
string
Temperature sensor name
reading
integer
Chassis temperature sensor reading, in degrees Celsius.
state
string
storage_bridge
string
Chassis throughput status
integer
errors
array[errors]
fc_ports
array[fc_ports]
firmware_version
string
Bridge firmware version
ip_address
string
IP Address
last_reboot
last_reboot
managed_by
string
model
string
Bridge model
monitoring_enabled
boolean
Indicates whether monitoring is enabled for the bridge.
name
string
Bridge name
paths
array[paths]
power_supply_units
array[power_supply_units]
sas_ports
array[sas_ports]
security_enabled
boolean
Indicates whether security is enabled for the bridge.
serial_number
string
Bridge serial number
state
string
Bridge state
symbolic_name
string
Bridge symbolic name
temperature_sensor
temperature_sensor
vendor
string
Bridge vendor
wwn
string
Bridge world wide name
