Manage automatic update configuration
Query and update automatic package update configurations using this API. Use GET requests to retrieve the settings or PATCH requests to modify the action field for a specific configuration.
Overview
Use this API to query and retrieve a specific automatic package update configuration.
This API supports GET and PATCH calls. PATCH enables the action field to be updated for the specified configuration.
Retrieving settings for a specific automatic update
The following example shows how to retrieve configuration settings for an automatic update category:
# The API:
/support/auto-update/configurations/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/configurations/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d"
# The response:
"uuid": "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
"category": "firmware",
"description": {
"message": "SP/BMC Firmware",
"code": "131072402"
"action": "confirm",
Updating the settings for a specific automatic update
The following example shows how to modify configuration settings for an automatic update:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/auto-update/configurations/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d" -H "accept: application/hal+json" -d '{"action":"confirm"}'
# The response:
200 OK
