REST API reference
Manage automatic update configuration
Query and retrieve specific automatic package update configurations using this API. You can update the action field for the specified configuration with PATCH calls, enabling tailored update management based on your requirements.
Overview
Use this API to query and retrieve a specific automatic package update configuration.
This API supports GET and PATCH calls. PATCH enables the action field to be updated for the specified configuration.
Retrieving settings for a specific automatic update
The following example shows how to retrieve configuration settings for an automatic update category:
# The API:
/support/auto-update/configurations/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/configurations/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d"
# The response:
"uuid": "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
"category": "firmware",
"description": {
  "message": "SP/BMC Firmware",
  "code": "131072402"
"action": "confirm",
Updating the settings for a specific automatic update
The following example shows how to modify configuration settings for an automatic update:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/auto-update/configurations/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d" -H "accept: application/hal+json" -d '{"action":"confirm"}'
# The response:
200 OK
