REST API reference
Manage multi-admin-verify approval requests
Access and manage multi-admin verification requests with these APIs to ensure that protected commands are executed securely. Submit requests for command execution, which must then receive approval from designated approvers in accordance with the associated rules.
Overview
These APIs provide information about multi-admin verification requests. If you need to execute a command that is protected by a multi-admin rule, you must first submit a request to be allowed to execute the command. The request must then be approved by the designated approvers according to the rule associated with the command.
Creating a multi-admin-verify request
Creates a request for the specified ONTAP operation.
# The API:
/api/security/multi-admin-verify/requests
# The call:
curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/requests?return_records=true" -H "accept: application/hal+json" -d '{"operation": "volume delete", "query": "-vserver vs0 -volume v1", "permitted_users": ["user1","user2"]}'
# The response:
"num_records": 1,
"records": [
    "index": 10,
    "state": "pending",
    "required_approvers": 2,
    "pending_approvers": 2,
    "execute_on_approval": false,
      "user1",
      "user2"
    "user_requested": "admin",
    "owner": {
      "uuid": "c1483186-6e73-11ec-bc92-005056a7ad04",
      "name": "cluster1",
          "href": "/api/svm/svms/c1483186-6e73-11ec-bc92-005056a7ad04"
    "create_time": "2022-01-06T16:59:49-05:00",
    "approve_expiry_time": "2022-01-06T19:59:49-05:00",
        "href": "/api/security/multi-admin-verify/requests/10"
Retrieving multi-admin-verify requests
Retrieves information about multi-admin verification requests.
# The API:
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/requests"
# The response:
"records": [
    "index": 1,
        "href": "/api/security/multi-admin-verify/requests/1"
    "index": 2,
        "href": "/api/security/multi-admin-verify/requests/2"
"num_records": 2,
    "href": "/api/security/multi-admin-verify/requests"
