REST API reference
Manage multi-admin-verify approval requests
Manage multi-admin verification requests to ensure secure execution of protected commands in your ONTAP environment. These endpoints help you submit and track requests that need approval from designated users before execution.
Overview
These APIs provide information about multi-admin verification requests. If you need to execute a command that is protected by a multi-admin rule, you must first submit a request to be allowed to execute the command. The request must then be approved by the designated approvers according to the rule associated with the command.
Creating a multi-admin-verify request
Creates a request for the specified ONTAP operation.
# The API:
/api/security/multi-admin-verify/requests
# The call:
curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/requests?return_records=true" -H "accept: application/hal+json" -d '{"operation": "volume delete", "query": "-vserver vs0 -volume v1", "permitted_users": ["user1","user2"]}'
# The response:
"num_records": 1,
"records": [
    "index": 10,
    "state": "pending",
    "required_approvers": 2,
    "pending_approvers": 2,
    "execute_on_approval": false,
      "user1",
      "user2"
    "user_requested": "admin",
    "owner": {
      "uuid": "c1483186-6e73-11ec-bc92-005056a7ad04",
      "name": "cluster1",
          "href": "/api/svm/svms/c1483186-6e73-11ec-bc92-005056a7ad04"
    "create_time": "2022-01-06T16:59:49-05:00",
    "approve_expiry_time": "2022-01-06T19:59:49-05:00",
        "href": "/api/security/multi-admin-verify/requests/10"
Retrieving multi-admin-verify requests
Retrieves information about multi-admin verification requests.
# The API:
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/requests"
# The response:
"records": [
    "index": 1,
        "href": "/api/security/multi-admin-verify/requests/1"
    "index": 2,
        "href": "/api/security/multi-admin-verify/requests/2"
"num_records": 2,
    "href": "/api/security/multi-admin-verify/requests"
