REST API reference
Update broadcast domain properties
PATCH /network/ethernet/broadcast-domains/{uuid}
Introduced In: 9.6
Updates the properties of a broadcast domain.
  • network port broadcast-domain modify
  • network port broadcast-domain rename
  • network port broadcast-domain move
uuid
string
path
True
Broadcast domain UUID
Request Body
Name Type Description
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
mtu
integer
Maximum transmission unit, largest packet size on this network
name
string
Name of the broadcast domain, scoped to its IPspace
ports
array[ports]
Ports that belong to the broadcast domain
uuid
string
Example request
  "ipspace": {
    "name": "Default",
  "mtu": 1500,
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1376484
Cannot change the MTU of a VLAN to be greater than the MTU of the port hosting it.
1377267
The specified IPspace does not exist.
1377269
Failed to lookup the specified IPspace.
1377560
Broadcast domain already exists in specified IPspace.
1377575
Remove associated subnets before deleting this broadcast domain.
1377605
Moving the system-generated broadcast domain to another IPspace is not supported.
1377609
Updates are partially complete. Updating broadcast domain attributes on some or all of the ports in the broadcast domain have failed.
1966460
The specified MTU is either too large or too small.
1967082
The specified ipspace.name does not match the IPspace name of ipspace.uuid.
1967150
The specified ipspace.uuid is not valid.
1967151
The specified ipspace.uuid and ipspace.name do not match.
1967152
Patching IPspace for a broadcast domain requires an effective cluster version of 9.7 or later.
53280884
The MTU of the broadcast domain cannot be modified on this platform.
53282013
Broadcast domain cannot be renamed because the name is reserved by the system.
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
node
name
string
Name of node on which the port is located.
ports
Port UUID along with readable names
name
string
node
node
uuid
string
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
ipspace
ipspace
mtu
integer
name
string
ports
array[ports]
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
